+ Reply to Thread
Results 1 to 2 of 2
Thread: Garage tips and tricks
  1. #1
    Join Date
    Oct 2008
    Location
    Mackay
    Age
    100
    Posts
    1,158
    Blog Entries
    1
    Rep Power
    20
    Default Garage tips and tricks
    Let us all know what little things you have come up with in the way of tips aqnd such for doing things in the shed or garage.
    I remember an old fitter telling me that he valve lapping paste every time on the tip of Phillips head screwdrivers..he claimed that he had far fewer rounded problems to deal with.
    I have used a little piece of Poly tetra fluoroethelene tape to protect the head of aluminimum or alloy bolts to stop sockets and spanners from marking them.
    Another one is to use that grey flashing tape on your rim before taking it to the tyre fitter for tyre replacement. The are less likley to scratch the rim with the tyre machine.
    any more??
    slow is smooth and smooth is fast.
  2. #2
    Join Date
    Jul 2009
    Location
    Cattle station North of Clermont
    Age
    41
    Posts
    386
    Rep Power
    8
    Default
    yes the valve lapping paste is a good one , i personally just rub the tip of the screw driver through the grinding dust left by the valve grinder.
    Another is removing siezed bolts is some times give them a good crack with a hammer & punch works about 70% of the time . If they end up breaking off & have a mig welder just keep building the remins of the bolt up with weld ,till you can grab with vice grips , the heat will loosen the bolt & the weld protruding will give you something to grab with the vice grips, works 99.9% of the time.
    Have heaps of others just can't think of them at the moment, Have I told you how to weld up a fuel tank "safely"using a vaccum cleaner??
    HARLEY DAVIDSON.................
    The most efficient way to turn gasoline into noise with out the side effects of horsepower!!
+ Reply to Thread
Similar Threads
  1. Garage Nights?
    By Bruce in forum In The Loop
    Last Post: 13th January 2010, 09:47 PM
  2. Motorcycle safety tips
    By Brett in forum Rider Safety & Gear
    Last Post: 24th October 2009, 11:01 AM
  3. Replies: 0
    Last Post: 26th July 2009, 08:40 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
